Unroll multiple polysurface?
Command Reference, Rhino 2.0: ftp://gdv.informatik.uni-frankfurt.de/pub/praktikum-ws01_02/RhinoDoc/Documentation/command_ref_us.pdf
Command Reference, Rhino 4.0: http://4.rhino3d.com/4/help/commandlist/command_list.htm
The command name ‘UnrollSrfUV’ is newer than the command name ‘UnrollSrf’.
The command named ‘UnrollSrf’ in V5 used a new algorithm to unroll surfaces. (See the quote by Pascal in Helvetosaur’s post above.) The new name ‘UnrollSrfUV’ was used in V5 for the command with the algorithm which was used in the command named ‘UnrollSrf’ in V4 and earlier.
How to run it
use the command RunPythonScript
Tens como adicionar a solicitação de colocar um nome antes da numeração?
If I understood correctly, you want to know how to add a name in front of the number?
sim exatamente, poderia me ajudar
What do you want to use for the name?
Descrição ou código, tipo: Prefixo+1,2,3,…
O ideal é que eu possa escolher o prefixo
