Unroll gives unexpected output
Hey everybody!
I am working on something were I want to get the unrolled surfaces from tubes that together form a circle. I just discovered this:
The unrolled surface is actually less long than it should. I start with a 50mm radius tube with mitre ends that I want to unroll. If this is done correctly it should end with an length of 314.159. BUT when I unroll this and measure this length I only get 308.838…
Does anybody has a clue of what’s going on? I am going nuts :frowning:
File attached
Sti
HELP.gh (74.8 KB)
n
Just pipe your 12 sided curve.
Try extracting an isocurve from the midpoint on one of the sections of the loft you created, or project a curve on the surface, I get a curve length of 308.830.
Pipe the curve and do the same, I get 314.159.
