Hi, I try to unroll flat cushion. At the moment I unroll each individual surfaces but it’s long and repetitive. Is it possible to unroll all the parts and label them? if it’s possible I 'll want to offset edges for seam allowance.
Thanks a lot Dfytz1! Your knowledge is impressive! I’ve to improve my surface construction for a best result. But it’s fine! I had points to know the up side and down side.
Can I add a “letter” or numbering for the order sewing after each other ?
At the end I use open nest for nesting all the parts. not very good at all but I learn a lot with the forum.
thanks. COUSSIN TRIBORD TEST V1.3dm (156.5 KB) unroll_dfytz_V1.gh (14.3 KB)
