Unroll dialog report, great and possible improvement
Hi
I got this message when unrolling a surface:
I like the improvement of a dialog to message the user when deviations beyond tolerance are found.
However in this case there is obviously something wrong with the starting surface.
Maybe the dialog should be a little smarter and report errors like these where no area is found in another way. The assumption that there is a starting surface area to begin with is false and makes this dialog look dumb.
( I cannot share the surface as it’s not mine and I am able to fix it)
Thanks
-WIllem
Hi Willem - thanks, I’ll see if we can tune this up.
Please provide a surface that demonstrates this problem. I have not seen this before.
I’ll try to dig it up. And send as a pm.
-Willem
Thanks William,
It’s on the bug list https://mcneel.myjetbrains.com/youtrack/issue/RH-45506
Greg
