I’m working on exactly this project but instead of sphere I got hot air balloon (H 12 meters). The object is huge and my graphic has size of 31,6 m x 16,5 m 72 PDI. I really hope I can insert such huge texture (not finished yet) in Rhino.
Is there a known size limit for textures in Rhino I should respect?
Do you mean 72 dpi? Is your graphic going to be 31.7 Giga-pixels? Or will it be lower resolution and “upscaled” for printing at 72 dpi? What will be the actual resolution of the base graphic?
There is absolutely no way you need 72dpi for something that big. You’d easily get away with 5dpi. Have a look at a billboard up close one day.
As a rule of thumb, the minimum viewing distance, which allows the whole image to be viewed in its entirety, can be calculated by multiplying the length of the diagonal of the item by 1.5.
Then use this handy table to work out the required dpi for continuous tone (ie. photographic) images
If you have vector art or text that needs sharper edges, then you are going to have to map that to your balloon then flatten that separately. Then colour that in Illustrator and assemble the whole horror show in InDesign.
Regarding texture size limit. That is mainly a hardware limit depending on the amount of VRAM in your video card.
If you go Tools>Options>View>OpenGL it will show you the max texture size in pixels you can use. Note that Rhino doesn’t report Vid memory over 4GB for some strange reason.
If you can’t fit your graphic into those limits, then look at multiple UV sets and deal with it that way.
Obviously there is a lot to this, but hopefully that gets you pointed in the right direction.
I managed with the image, the printer company did not accept lower than 72dp. My flattened PSB file was 1.7 GB.
However, as I’ve said my 3D shape is an air balloon and not like the subject of the discussion here - a sphere. No mapping worked for me so I simply converted my nurbs to mesh and without mapping the texture fits perfectly well (of course I had to play until I found the right proportions of the texture).
Now I can’t split the mesh properly - always getting jagged edges. I run both:
The problem also would be if I decide to keep just 1 segment (24 in total), than polar array it 24 times - I’m getting the same piece of texture and as I have not mapping method applied I can’t change / rotate the mapping for the rest of the segments.
Any idea how should I get mesh split doing better job?
thank you
Model in Nurbs first.
Split that up for your panels. Join these into one polysurface.
Mesh this polysurface to a reasonable density. “Reasonable” being dense enough to approximate the shape but no more.
Now apply UV mapping such as cylindrical or spherical and tweak the mapping widget a bit as appropriate. You don’t want surface mapping as this will not behave when you explode the mesh.
Apply your texture. You may need to do a bit of pre-distortion to get it to work nicely.
Now you can explode the polymesh and you’ll get your textured panels ready to flatten.
Regarding resolution. If your printer wants to shove a 1.7GB file through their RIP then I suppose that’s their problem
However you might want to discuss scaling with them.
One strange thing appears. The curve you can see comes from the engineers and that is how my flatten texture should be shaped. Strangely my mesh seems twisted like it’s out of symmetry while I have spent long time for generating this beautiful mesh and everything is symmetrical. Any idea ?
This happens a lot with Squish if you have singularities (ie. the pointy tip of the gore panel)
Trim a bit off the gores and mesh that.
The other trick is to make the panels Degree 1 across the panel. After all they will be cut from flat fabric anyway
@Steve_Howden , I do something wrong. I trimmed a bit off the gores on the top but it does not get better. Maybe I should trim off much more?
Talking about _changeDegree to 1 totally deforms my nurbs segment into 3 flat areas. Is there something I can use to treat the mesh for getting better squish after?
Maybe my particular workflow caused this issue with Squish, which is:
I work on 1 segment only which has 2 surfaces
both surfaces go in GH turn to mesh and merge in single one (perfect quads)
polar array of the mesh and Group (this allow to see the texture on the whole balloon). Doesn’t matter the tons of widges generated.
the topic remains unsolved for me.
I now use Version 7 SR20, however when I _squish 1 segment (which mapping is still spherical after exploding the sphere) I got flatened version but the mapping is diferent (stil spherical thought). Any thoughts how to proceed? Thank you
Hi Alex - Yeah, I know - this does not work… the way out, I believe, is to Bake the surface to a high-ish resolution image, then Mesh the surface and Squish the mesh… The problem is the spherical mapping gets transferred to the flattened object where of course it no longer makes any sense - by ‘baking’ the texture you can sidestep the mapping completely.
