Unlocked layer selection issue
(Ahmed Madani7) #1
I can’t select a layer even though it is unlocked
(Wim Dekeyser) #2
Hi - if you are trying to select geometry that is on an unlocked layer, it is possible that the geometry itself is locked. If that doesn’t help, please post a 3dm file that shows the problem.
(Ahmed Madani7) #3
That is not the issue.
Please find attached file.
Regards,selection issue.3dm (9.4 MB)
(Wim Dekeyser) #4
Hi - expect for some geometry on the green Layer 04 layer (deleted in this picture), all of your geometry is on locked layers. You need to expand the parent layer to find the locked layers.
HTH,
w
(Ahmed Madani7) #5
Thanks, It skipped my eyes for some reason.
I have another problem lofting two of the three curves.
Regards,loft issues.3dm (11.9 MB)
(Wim Dekeyser) #6
Hi - there’s a huge amount of extremely short straight lines in those curves.
I would recommend to join these and rebuild to a much smaller amount of points - in the attached file I used 20 points because 4 segments of your curves were 20 points each. The flat upper and lower parts of that shape can be made with EdgeSrf or PlanarSrf.
You should play a bit with the rebuild settings to see if you can simplify those curves some more while still keeping the shape that you are after.
loft issues-wd.3dm (1.4 MB)
HTH,
w
(Ahmed Madani7) #7
Great, much appreciated!
(Wim Dekeyser) split this topic #8
A post was split to a new topic: Scale without exploding the lines
(Ahmed Madani7) #9
How to flow along surface in this case (pls check file).flow along surface.3dm (1.2 MB)
(Pascal Golay) #10
Hello - please start a new thread for this question.
(Ahmed Madani7) #11
Will do,
Thanks.
