Would anyone know what was the first action performed in this YouTube video is, regarding the way he has traced the outer shape into a 3D object? I have tried using the flow tools but have failed numerous times, and I cannot find an answer anywhere. Thank you.
Hi, possibly Revolve
around a central axis.
Thank you so much. Sorry, it is my first time using Rhino
No need to apologize. Have fun with Rhino. The forum here is usually very helpful if you have questions.
Hello again. I am having difficulties with the second action completed, involving the smash command. When he copies the revolved surface, he smashes it all as one piece. However, when I go to smash the surface, I can only select one surface (image below). Even if I smash each piece individually, I cannot manage to piece them together. Any solution to this? Thank you.
