Update plugins was working fine till the last servise relase
Hello - MigratePlugIns
or PackageManager
are two commands that might be what you’re looking for.
Hi - Please run the Rhino SystemInfo
command and copy-paste the result here.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Evaluation, build 2020-12-08
License details: Stand-Alone
Expires on: 2021-02-10
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [38% battery remaining]
Primary display: Intel® HD Graphics 520 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
Primary OpenGL: AMD Radeon ™ R7 M360 (AMD) Memory: 4GB, Driver date: 10-27-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.12.1 27.20.11027.5002
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-27-2020
Driver Version: 27.20.11027.5002
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Geometry Gym\Rhino7\ggRhinoIFC.rhp “ggRhinoIFC” 2.0.10.0
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.5.4.0
C:\Program Files\Geometry Gym\Rhino3d\ggKaramba.rhp “ggKaramba” 0.2.3.0
C:\Program Files\RhinoNestRhino6\System\RhinoNest.rhp “RhinoNest” 4.6.18354.2
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.0.1.0\XNurbsRhino.rhp “XNurbs”
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.0.0.0\KeyShot10RhinoPlugin\Rhino 5.0\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.0.0.0
D:\Windows.old\Users\huss1\Desktop\softwares\Architecture soft\Mesh2Surface 6.09 Premium\m2s_for_Rhino6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RhinoFileVersion\7.0.0\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
Thanks for that information.
I guess I was thrown off by that screenshot but looking closer, I see that the Help > Check for Updates...
menu item does, in fact, run the ~-_OptionsPage _UpdatesAndStatistics
macro on your system.
This opens the following dialog, doesn’t it?
At any rate, after some digging I found that the UpdatePlugins
command was removed from Rhino 7. I’ve created RH-62152 to removing it from the Rhino 7 documentation.
The new MigratePlugins
command moves V6 plugins into V7 - V5 plugins aren’t supported.
