Hi Brian
In the Last Wip (6.0.14246.9041, 03/09/2014)
The command TestAutoPointsOn don’t works.
Unknown command: TestAutoPointsOn
Ciao Vittorio
Hi Brian
Ciao Vittorio
As far as I remember, those commands would only be around a short time to test the initial concept.
Same as “TestPointsOnSelect”, which was the first command for this functionality. They have both been removed.
Are you trying to turn off the behavior of having points come on when you select a curve or dimension? If so, why?
Hi Wim
thanks for the information now okay
Ciao Vittorio
