Units change issue/bug?
In the Beta, it’s great that geometry gets scaled correctly when I change units, but for some reason text does not. Is that a bug or is there a reason for it?
Also, when I try to change from MM to inches, Rhino warns me that I’m changing from No Units to inches, which is incorrect.
Hi @phcreates,
Always best to include a file.
Thanks,
– Dale
Hi Peter -
It’s hard to say what exactly is meant by that. When you only change the unit system, the model scale of annotations are unchanged. When you maintain object sizes, the model scale of annotations is changed according to the change in units.
Thanks. I’ve filed that as RH-98855 Units: Mixed Units Warning
Here when I change the model unit system and select maintain object sizes, a text block does not change correctly according to the change in units. So, a 1" block of text becomes a 645mm block of text.
Hi Peter -
I had only checked with dimensions the other day. I see that this does not work correctly for annotation text.
→ RH-99011 Text: Change Units - Size Issue
RH-98855 is fixed in Rhino BETA
RH-99011 is fixed in Rhino BETA
