In the attached file I have two a pair of closed polysurfaces (bottom) that I would like to join to form one polysurface (top).
I created the copy one by exploding and slicing and joining
But, is there a simpler way?
Problem Unite.3dm (3.0 MB)
Hello - BooleanUnion
works here. If. instead, you want a miter, split with a vertical plane and delete the short bits.
With MergeAllFaces
applied:
Because I had to do a number of these, I took the miter approach. Because the sides are not vertical, a straight line would not work. Instead, I had did an intersect and drew a poly line alone the corners of the resulting box then used that polyline to split.
Thanks.
you can use booleanSplit first, delete what you want and then boolean union and mergeallfaces.
