Unintended Floating Viewports are created when Restoring Named Views.
In this file, I manually deleted the Named Views created by the ClippingDrawings but I don’t know if that is related to the problem or not? - I recall the same problem was reported once in Rhino 7.
Question: Is it possible to create ClippingDrawings from multiple ClippingPlanes added to Groups?
This could be a separate topic using the same Rhino 9 file as an example. Please split if needed.
Regarding your first issue - unintended floating viewports - I’m not able to reproduce this here – restoring C1, C2 and C3 (from the Named Views panel and with the NamedView command) restores into the current viewport and no floating viewport appears.
Can you tell me:
Are you on Windows or Mac? Getting your SystemInfo would be a big help.
How do you restore the view – double-click in the Named Views panel, the Restore button, right-click › Restore, drag onto a viewport, or a command/macro?
Does it happen every time, or only after running ClippingDrawing (or after some other step)?
If you can list the exact steps from opening the file, I’ll give it another try.
My SysInfo is on another post from today. I noticed the floating viewports when dbl-clicking the thumbnails in the Named Views Panel when I had four ViewPorts (not a fullscreen ViewPort).
I’m running Windows version of Rhino 9
Hope that helps.
Tim
I agree. The Viewport is not floating but it seems like it is If you maximize the C1 Viewport and do the same as you have discribed in the RH-99996, you will get a really ugly interface very fast.
