Uniform vertex indices across model problem?
Hi, I am having a problem selecting the same vertex in every hex cell at the same time, I have noticed that they don’t have the same indices, so how I can make indecis to be uniform across the model like on the sketch, and i need to use Triangle Panels b and Dual Graph components?
Vhex.gh (16.0 KB)
Assuming you have control about each hexagon. You can sort like this:
  • Average all 6 vertices to get a center
  • get the topmost point, by sorting out by z
  • Create a plane at the center point in a way that the local x axis is pointing to the topmost point
  • Create circle
  • Sort Along curve
  • Shift the list for one index
This is almost the same method as @TomTom said except using the planes from your original surface.
Vhex_re.gh (21.3 KB)
You can also use this method by finding the minimum Z value, choose their points and shift lists of the original points than you can change the start point as you want
z
Vhex2.gh (20.7 KB)
So awesome, thank you guys! every solution did the trick =)
