hello,
why do i get a rectangle rotated, when i place it on every node of an ellipse via script?
thanx
stan
Orient Direction just uses Points A → B to define one translation and vector vA to vB for minimal rotation
if we could sort-of slow motion the transformation in steps to visualize what’s happening, it might look like this:
if you want the original Curve to be oriented using a Plane reference, maybe Orient is what you’re looking for:
Classic_Orient.gh (13.3 KB)
Have you specified a corner radius? I had problems with rectangles rotating 90 degrees if a radius was specified.
hi, thanx, so the rotation is implemented…hmmm…
i used the wrong fuction, surely i needed ORIENT…thanx a lot !
stan
hello and thanx! as written above, i used a wrong function.
and no, i projected omly simple curves without further modifications (corner radius).
regards
stan
