After becoming better acquainted with Rhino 6, I decided to start learning Grasshopper. In one of my first, very simple models, I found that one of two very similar geometries produces an error in the ORIENT component and the other one, located in the same YZ plane does not. (I am attaching the .3dm and .gh files).
The problem does not occur when the offending part is rotated out of the YZ plane.
I have tested about 50 more different parts, also placed in the YZ plane, and no errors have been produced.
The components are easy compared to the concepts behind them, including data trees. I just noticed that your final output is a âGroup with 9 objectsâ instead of the curves you really want?
Itâs been a bit longer than I expected but, to seriously learn Grasshopper, I decided to make a more complete program that anyone can use.
Discovering and learning about each GH module meant to modify and rewrite the program dozens of times to take advantage of these functions.
I would like make it available in the forum for anyone that may find it useful. If it is no abusing your patience, I would be grateful is you revise it first, and tell me the best way to go about it.
I sent a copy to Petras Vestartas to thank him for the OpenNest plugin and to hear some comment on my program since, may be, I used OpenNest in a somewhat unorthodox way.
One benefit for me would be to learn from possible improvements by other users.
I am attaching a PDF with instructions on how to use the program and a compressed file containing the GH program and a Rhino file with sample geometry. Nest_Pack.zip (2.2 MB) Instructions for using NEST-PACK program.pdf (575.0 KB)
