The idea behind is having a grid of points that can adapt to the XY rectangle dimensions.
My approach was to divide X and Y length in a pre-defined sequence
for Y every 250 (code should add more of this sequence in case Y dimension grows)
for X a sequence of 175 (b/2) 100 (a) (code should add more of this sequence in case X dimension grows)
I’m feeling a bit stuck here, I’ve been checking some other posts and I’ve not been able to figure it out, I’d appreciate some help here.
Hi Inno, first of all, thanks a lot, didn’t thought about using pufferfish plugin!
I’ve been going through the code and there is something that I can’t solve.
As you see in the images when the X length of the rectangle allows the sequence to starts and end with “175” the distance is equal in both sides, however when the X length changes to another value the grid it’s not centred anymore, giving as a result 2 different distances on the side (Image example: 190.99 left , 103.31 right)
Hi Inno, thanks for your reply, I may not explained myself well.
So as you said 80 (variable depending on “X size”) on each side is correct, that’s the main part, but what I also wanted to achieve is to start and end always with 70 “X division length”.
