it seems that the button in the CPlanes toolbar to undo / redo are referencing two unknown commands. I guess the button command should be changed to:
_CPlane _Undo
_CPlane _Redo
I’ve not listed the nested symbol in front of the command, as both seem not to work anymore during other commands, eg. when i am within the creation of a polyline.
When i change it as in your pic above and use it while drawing a line, it does not work:
Command: _Line
Start of line ( BothSides Normal Angled Vertical FourPoint Bisector Perpendicular Tangent Extension ):
End of line ( BothSides ): '_CPlane
CPlane origin <0.000,0.000,0.000> ( All=No Curve Elevation Gumball Object Rotate Surface Through View World 3Point Undo Redo ): Undo
No CPlane to undo.
Ha, don’t jump to conclusions (-:
It could be that mine is not updated. I never use toolbars and am not the one to notice if things don’t work with those…
Hi Clement - I know… it is not really too clear what users should do - resetting the toolbar unpacks a new one from the latest download and replaces default.rui. (Which is why you should rename default.rui files if you modify them). Installing does not replace the default. rui file…
