Hi all,
I was testing command features into the WIP and I found something that seems is not working fine. When youre inside of a command and the user does a CTRL+Z(Undo) the command line prints “_Undo” and it doesn’t close the command. This is nice if you have a command line option “Undo” because it’s going to be detected inside the command itself.
Despite of that, the “Redo” shortcut is not working in the same way since it cancels the command and after that seems it’s calling the Rhino “Redo”. Does this makes sense? In my point of view Undo/Redo should be called in the way “Undo” does right now, to allow the developers to put it as a command Option. I attach a picture of the command line.
Regards,
