I have a problem with Undo, Redo, Copy command.
When undo, redo, copy command is called, they affect my plugin data.
For example,
protected override void ReadDocument(RhinoDoc doc, BinaryArchiveReader archive, FileReadOptions options)
byte[] bytes = archive.ReadByteArray();
MemoryStream stream = new MemoryStream(bytes);
IFormatter formatter = new BinaryFormatter();
MyClass data = formatter.Deserialize(stream);
When I read documents, my plugin deserializes its data from the document.
After that, If I press CRTL + C (CopyToClipboard
), deserialized data from ReadDocument
are also copied to clipboards.
Then, if I press CRTL + P(Paste
), my ReadDocument
logic is called again.
Another example,
In my WPF ListView, ListViewItem has checkbox that it is checked when rhino mesh is selected.
And when selected mesh is deleted, checkbox is unchecked.
But if I press CRTL + Z (Undo
), checkbox is checked.
I want to block Undo, Redo, Copy, Paste command in my rhino plugin.
Is it possible?
- Kyungmin
