Undesirable split surfaces
I would like to raise one issue, it concerns the undesirable division of surfaces in an object with many connected surfaces. It usually happens when I remove one of the walls from the object. Logically, there is no basis for such a division, the situation is saved by disconnecting all the elements, removing the surfaces and connecting them again. These undesirable divisions are often random and are not necessary for anything. Currently I am not posting a screenshot, if such a situation arises again, I will add it. However, perhaps some of you have already encountered something like this?
You need to post a picture or a file.
Hi Robert,
Could you post the model as it was just before you deleted the highlighted panel?
Thanks
Jeremy
It looks like when you “removed” a wall, it forced Rhino to readjust your surfaces to maintain the edges connected. It probably added a huge amount of knots to the surfaces where you see the lines. This is not a good workflow.
Ok, but when i explode elements, there is no problem. then, i can join them again with no divides.
