I want to generate a shape that can stay under the water like a submarine. For this it should be dynamically adapted to the water. It should also look futuristic. Do you know any plugins / components with which I can test shapes on streamline underwater?
AND
Do you know plugins that allow you to create biological shapes that imitate nature (animals, molecules, plants, etc.)?
Iâm very curious whatâs floating in your head as an idea.
The description is, to say it mildly, not very descriptive for a clear idea.
The main difference between a surface ship and a submarine is that the center of buoyancy and center of gravity of a sub coincide (the ideal case). Which means the weight of the sub and the weight of the displaced volume of water are equal (in case of pure water volume of the sub multiplied by 1 if you consider a bubble of a structure with negligible weight).
I honestly donât know what you mean by this. Do you expect some kind of a foam or rubber baloon that should float above water? For this all you need to do is pick a âfuturisticâ shape of a baloon fill it with fluid a bit lighter than water so it wonât sink and heavier than air so it wonât fly away in case it is big enough that the surface tension is negligible.
This is another thing I do not fully understand. Nature is pretty chaotic thing that sometimes forms shapes following the chaos theory. There are plenty of plugins that provide different patterns taken from the nature. Check http://www.food4rhino.com
Sorry for making it not that descriptive. Unfortunately Iâm still in a early design stadium.
I also thought about the fish, jellyfish stuff but even if itâs â50sâ, itâs still obviously one of the best shapes for underwater âŚthanks to evolution. I thought maybe someone knows some more innovative ideas on that topic.
Currently Iâm formfinding with mosquitos flow component which shapes are more or less effecient underwater.
Concerning my other question about ânature imitating pluginsâ, I already had a look at food4rhino of course, but I was thinking maybe one of you have good experiences with some plugins on that topic.
I donât think there are single plugins which can generate nature-like shapes. For a start you can use some of basic plugins to imitate nature. Look at this book, chapter 4:
âTransformation is a great potential to generate complex forms from simple objects. Nature has some of the greatest examples of transformation in its creatures.â
In general, Iâd think more precisely about what it is that you want your design to do well, related to the environment it will live in! Pick a few parameters and try to optimise towards those (maybe start at the most achievable or important).
The overall shape of a fish, down to the pattern of its skin and functionality of its inner organs, is mostly optimised for speed and agility at low caloric cost. If you need to flee predators all the time, you need to be fast, but use the least amount of energy possible. After surviving an attack, you still must be able to get food, in order to replenish your resources and start the circle of life anew.
Fish evolved over millions or trillions of years, which optimised each species for what it needs to do up to now in its more or less stable environment.
Obviously the downside to this is that when your environment changes rapidly, youâre pretty much f***ed. Evolution takes thousands of years and many more generations of a species to make big changes, thus allowing it to adapt and survive.
We humans are to a degree an exception this, since we have a creative nature, meaning that we like to come up with stuff that make our lives easier or satisfy some primordial feeling that still slumbers inside us, since one of our ancestors crawled out of the primeval soup.
The next generations will probably see how adaptable, we truely are through our ingenuity, if the world around them turns into an erratic, climatic hell.
There really are no true nature imitating plugins, but there are some that try to emulate principles or concepts that we humans fancy ourselves to have discovered in or extracted from nature (i.e. emergence, L-systems, Vornoi patterns, phyllotaxis, genetic algorithms, phenology, [machine] learning, etc.) and do our best to imitate.
If you want to play god, in that god is an extrapolation of human qualities and abilities to the infinite, and thus the mysterious creator of everything that you canât explain at the moment, you might be interested in genetic algorithms, emergence, and even machine learning. But your goals must become clearer first. Thereâs no sense in optimising towards an unknown ideal.
Also, the pitfalls of optimisation strategies are often that the most optimised isnât the most sexy thing. Letâs say you optimise towards flotation. I imagine that you would topologically end up with some kind of sphere, which is fine, but boring! Now you need to introduce more parameters to evolve towards a more interesting object.
After hundreds of parameters, iterations, and tries, youâll then discover that this still wasnât enough, that some spice is missing, but youâll accept your optimised, yet imperfect object. However, youâll also discover that we simply currently donât have the processing power, data pool, and imagination necessary to mimic the complexities and apparent chaos of nature. Millions animate and inanimate objects interact in millions of interacting environments at different scales to produce the intricate, beautiful system that we humans describe as nature and that we live in. By the way, this also why the weather forecast sucks and isnât reliable for more than two to three days, if at all.
So my advice is, do your research about the environment and how objects that live in it have solved some of the challenges it poses. Go crazy on the design and donât shy away from giving it your personal touch. Now you can computationally optimise your prototype towards some interesting or important goals within the boundaries of your current design.
But remember, pretty much each simulation and optimisation that doesnât respect all of natureâs parameters is probably futile, or is it?
