I managed to split a mesh object with meshsplit but it created a piece which I cannot select or delete. please help!
Can you post the file? Or at least the undeletable part? (Save a copy of the file and delete all other objects )
Sounds like you have an object with a damaged edge curve that is confusing the mesher.
SelBadObjects will probably select it so it can be identified and either deleted for repaired.
undeletable piece.3dm (119.0 KB) don’t know if that will work, I just trying the selbadobjects and it didn’t work, thanks though, please let me know if you cannot access this file.
The object is locked. Use Unlock or UnlockSelected to unlock it…
Thanks, worked! much love.
