I need to fill the wood material in the chair… but the backrest (which is a polysurface) is not showing the material in the rendered mode, while the other parts of the model(which is a mesh) is show.
(also, there are two mesh -of the cushion of the chair [if you select the cushion, another one below it gets selected as well] and i am unable to split them. If someone can help me out with it? I have attached the link of the model for the same)
Hello - just to be sure, please open Options > View > Display modes and reset the Rendered mode to defaults. Does that do anything? If not please run the SystemInfo command in Rhino and paste the results here.
Hi-
it worked! I see the material on it now… But was wondering why does the material appear differently on the mesh (legs of the chair) and the polysurface (backrest of the chair)
