Unable to trim surface made of pixelated surface
V5
Having carefully trimmed my way thrpugh a complex object I see this item which had been used to trim the surface under it, still has a surface as base under it, or is it ? its a sort of pixelated mess still there.
Selecting the walls of the item to trim a hole in that sheet it wont trim that pixelated mess away.
so is that an optical illusion, is it ok to join it to that base sheet ?
The object which that forms a part of doesnt seem healthy unless that is a decent hole !
trim messy surface.3dm (590.1 KB)
Steve
Hello- no idea how it got this way but you can DupBorder and then PlanarSrf on what you have and just replace the surface with the new one.
Hi, ok will do.
Steve
