Unable to Subscribe to Grasshopper DocumentRemoved Event
import Grasshopper
print(type(Grasshopper.GH_InstanceServer.DocumentServer.DocumentRemoved))
print(type(Grasshopper.Kernel.GH_DocumentServer.DocumentRemoved))
print(type(Grasshopper.Instances.DocumentServer.DocumentRemoved))
DocumentRemoved.gh (10.5 KB)
@eirannejad
It seems Grasshopper module in Script component refers to Grasshopper2.dll.
import Grasshopper
a = Grasshopper.__file__
@eirannejad
Could you please check this? The script component is still referencing grasshopper2.dll.
@Mahdiyar I have logged the issue here
The problem is both GH1 and GH2 use the Grasshopper namespace. This means python 3 will combine all the sub types and namespaces in both these assemblies under the same Grasshopper namespace.
This effectively replaces Grasshopper.Instances from GH1 with Grasshopper.Instances in GH2
RH-76310 Python 3 binds Grasshopper namespace in both Grasshopper.dll and Grasshopper2.dll
I’ll discuss with David and will look into this
Checking for __file__ is not a valid way of determining which dll the namespace is bound to as it could be multiple dlls.
Thanks for pointing that out.
I primarily need access to the Grasshopper DLL to identify the locations of the libraries and user objects folders, which is essential for adding a DLL reference, especially in Rhino before Grasshopper is loaded.
import Grasshopper as gh
import clr
clr.AddReference(str(gh.Folders.AssemblyFolders[0]) + "KangarooSolver.dll")
import KangarooSolver as ks
Additionally, our plugin, Euglena, has used this approach in the past to copy .ghuser files into the User Objects folder.
import os
import shutil
if run:
    source = os.path.join(directory, "UserObjects")
    destination = gh.Folders.DefaultUserObjectFolder
    for item in os.listdir(source):
        item_path = os.path.join(source, item)
        shutil.copy2(item_path, destination)
    try:
        __import__("euglena")
        print("Succeeded!")
    except ImportError:
        print("Failed.")
You can use the HostUtils static methods for this:
GetAssemblyPaths.gh (6.9 KB)
