Unable to snap object in layout detail view
I’m not able to snap object again in the layout detail view where I was able to do,
the object snap options are all turned on, what else might also lead to this problem?
objectsnap
(If file is needed, I’ll send via email.)
SystemInfo.txt (3.1 KB)
Hi @Tanik yes please share the file. That always helps! you can send it to visualarq@asuni.com
@Tanik no need to send me the file. I could reproduce the problem.
@fsalla When I tried to export selected to a new file. I found that I’m able to snap the object again in the detail view of the newly exported file, but at the same time the section hatch’s pattern scale is messed up, parameters are missed. Here I reported a new issue.
Hi @Tanik, can you share the original file as well? then I can compare the hatch patterns with the “exported selected” file.
