Unable to select object
I came across a few instances where I am unable to select the object. Such as, when I try to trim, I select the trim option, sometimes I have to make several attempt on clicking the line before I am able to select it and trim it.
Another is when I am following the pen tutorial from McNeel to create the overmold, when I click the extractsurf, I am unable to select the object to duplicate. The layer is not locked and the object is not locked. Any suggestions on how to fix this?
Thanks,
Annie
Hi Annie -
Without more details, it’s hard to know what’s going on.
Have you tried a different mouse?
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
Thank you for your reply. Here is the information. Not sure if this would help.
Hybrid graphics system.
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
Thanks,
Annie
Hi Annie - please post the entire contents of the SystemInfo output.
Hi Pascal,
Please see below.
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Commercial, build 2019-02-27
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-K9JK9HC
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Rhino plugins
Hi Annie - please install the most up to date Rhino - Help > Check for updates, then see how it all works.
ok thanks Pascal for your recommendation
