Unable to select hidden objects when using flow and flowAlongSrf
When using flow and flowAlongSrf, if the curve or surface, which is the criterion for selecting objects to be processed with flow, is obscured beyond the object like a rendering view or shaded view, there is a phenomenon that it cannot be selected. In Rhino 5, even if it is obscured by other objects, it will be selected well if the object is located where I want to click.
Rhino 7 SR7 2021-5-31 (Rhino 7, 7.7.21151.13001, Git hash:master @ 24d76fc798fa6ffd33733e5f18b034d547b87840)
License type: 상업용, build 2021-05-31
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 4-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 466.27
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-23-2021
Driver Version: 27.21.14.6627
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21151.13001
Hello - I see this, thanks. Picking has been changed some since V5, I am not sure how that has affected this case, but I will get it on the list for the developer to look at.
RH-64786 FlowAlongSrf picking behavior
In Rhino 5, as with general selection, hidden objects are selected well in flow or Sf flow. In Rhino 7, if the change is intended to prevent the selection of obscured objects, I think it is a downgrade in terms of convenience. Can’t we roll back the selection like Rhino 5?
  1. Also, why doesn’t the polyline or surface erected in the X-axis not show up in the floor plan even after 2 years?
Rhino 7 SR8 2021-6-23 (Rhino 7, 7.8.21174.15001, Git hash:master @ f30806bf209be7547baaa5decc53b3dbc50946ff)
License type: 상업용, build 2021-06-23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21174.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21174.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21174.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21174.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21174.15001
