Unable to Run Purge as Idle Process Automatically
I just installed Rhino 9 Beta today to test and experiment with some of the upcoming features and have run into an issue with how the Purge command works.
Configuration to my existing longtime installation of Rhino 7, includes idle processes. Among the list is of idle processes is running the Purge command.
On Rhino 9, when the Purge command is run, Purge opens its own “pop-up” window with a list of checkboxes for what types of entities the user wants purged. This window halts the idle processes as it is waiting for user input to confirm their selections. My other idle processes will not continue until I have manually confirmed OK.
Comparatively, in Rhino 7, Purge has all of its command properties displayed inline in the Rhino command-line, which notably does not require user input when run as an idle process.
Am I missing a new setting or method to skip this R9 Purge window or is this something that cannot be avoided? Personally, I would greatly prefer that Purge’s preferences be reverted to the command-line, but at the very least, a method allowing idle process to skip manual user input on the Purge window would make it serviceable for my use case.
Both versions have the exact same idle processor commands and are as follows
Idle Processor:
Purge _Enter
SD
Save
I have to manually press Enter, alt + K, or click OK on R9’s Purge window to continue, R7 takes the _Enter input as confirmation and continues automatically
Since Rhino 8, Purge shows a dialog when run interactively. For scripts, macros, and the Idle Processor, use the command-line version by prefixing the command with a dash:
-_Purge _Enter
SD
Save
-Purge shows the same Yes/No options on the command line as Rhino 7 did, and _Enter accepts them. It shares its settings with the dialog, so whatever categories you last checked in the Purge dialog are what -Purge purges. You can also set individual options in the macro, for example -_Purge _Materials=_Yes _Enter.
– Dale
