Unable to project curves on a SubD?
Assuming this is a known issue, but couldn’t find in search.
Unable to project or pull curves onto subd objects. Can section, run intersections.
Would be nice.
thank you.
-Robert
Project and Pull work if you preselect the curve and SubD. There’s an open item about this, RH-55250, and I added your comments… Thanks.
OK great thank you for work around for now. Need normal method for changing settings of course.
Any news on this?
In the (7.0.20084.11445, 03/24/2020) looks like is still not working.
After the curve is projected onto the SubD is it possible that this (the curve) becomes part of the SubD? Is there a specific command?
This broke but has been fixed… https://mcneel.myjetbrains.com/youtrack/issue/RH-57570
It should work for you again in tomorrows WIP.
No, the curve is still a curve.
Could it be an interesting idea that the curves projected on SubD can become an integral part of the SubD surface? What do you think about it?
Hi @davide76
you can use Align>ToCurve to align selected Sub-D control points to the projected curve.
HTH, Jakob
