Unable to open panel as sibling of Layer panel
I have been trying to open a panel as a sibling of the Layers panel in Rhino, but the call to Panels.OpenPanelAsSibling always returns false. It is unclear as to why this method returns false, unless I missed this information in the documentation. The panel does open as expected when calling Panels.OpenPanel.
This is a .net6 wpf application and the TempView in the code below is an empty UserControl.
I am currently using Rhino WIP, 8.0.23164.14305
The project is referencing the following packages:
RhinoCommon 8.0.23125.12175-wip
RhinoWindows 8.0.23108.14305-wip
public class TestPanel : Command
        public TestPanel()
            Instance = this;
            Panels.RegisterPanel(
                MyPlugin.Instance,
                typeof(TestPanelHost),
                "Test",
                System.Drawing.SystemIcons.WinLogo,
                PanelType.System);
        ///<summary>The only instance of the MyCommand command.</summary>
        public static TestPanel Instance { get; private set; }
        public override string EnglishName => "TestPanel";
           var panelId = typeof(TestPanelHost).Guid;
            if (!Panels.OpenPanelAsSibling(panelId, PanelIds.Layers, true))
                Panels.OpenPanel(panelId, true);
            return Result.Success;
    [Guid(MyPlugin.TestId)]
    public class TestPanelHost : WpfElementHost
        public TestPanelHost() : base(new TempView(), null)
I am unsure if this is a WIP bug or if this is the result of some misconfiguration, any help would be appreciated.
