I hope this message would be read by the developers
Once i’ve ran a Rhino.Inside.Revit add-in in Revit 2021 i can no longer open any other workshared cloud models. Restarting Revit completely resolves the problem.
Recovering by opening the model with inspection or with the worksets being turned off also doesn’t help and may even completely freeze the program. >.< Simultaneously Revit 2020 has no such problem on my machine. I have no idea if the bug issues also on the other machines
This is most probably a DLL conflict with the cloud APIs. Would you mind testing a scenario that you open a cloud model Before running RIR and then opening RIR and see if you can still sync? I’m trying to figure out if the cloud dependencies gets loaded first, would it solve the problem or not. I have BIM 360 access on my side now so I can test more as well
I know this might look like i’m in a rampage of bugs detection haha, but i like to report bugs and i didn’t have enough time to report this events
In this case, i had rhino.inside executed after closing a cloud file. Then i opened the same file again, while rhino.inside was still open. So this warnings of licences and worksharing shows. This happens everytime this condition meets.
