jmv
jmv
That’s correct. You can’t edit referenced files.
OK,
I can place a referenced layer inside a parent.
And I can’t put this referenced layer back outside of its parent.
I have the same problem.
Download these files:
WorksessionA.rws (560 Bytes)
File 1.3dm (1.6 MB)
File 2.3dm (1.5 MB)
Open Worksession A. File 1 will be opened as the active file, and file 2 as a reference file.
Move File 2 under Layer 1 in File 1. This can be done the same as moving any other layer.
File 2 cannot be moved.
Workaround to move the reference file back to the top level:
In Worksession:
Select the reference file which has been moved and make it the active file.
Make another file the active file.
Close Worksession
@Wim This should qualify as a bug which needs fixing.
