“Unable to load RhinoAI.rhp plug-in: ID already in use”
Rhino-MCP-Platform 0.3.0: “Unable to load RhinoAI.rhp plug-in: ID already in use”
Setup: Rhino 8.35 (Educational Lab License), Windows 11, .NET Core v8 set via SetDotNetRuntime.
What I did: Installed Rhino-MCP-Platform 0.3.0 via Yak (yak install Rhino-MCP-Platform) and also once via the Package Manager. Reinstalled after a clean uninstall.
Problem: On every start Rhino shows “Error loading - RhinoAI.rhp”. Details: “Unable to load RhinoAI.rhp plug-in: ID already in use.” Loading the plug-in manually via Options > Plug-ins > Install gives the same error. The plug-in does not appear in the plug-in list, and MCPStart is not recognized.
What I checked: There is only one RhinoAI.rhp under %APPDATA%\McNeel (in packages\8.0\Rhino-MCP-Platform\0.3.0\net8.0). A search for *.rhp there finds nothing else. In C:\Program Files\Rhino 8 the only match for *AI*.rhp is export_AI.rhp (Illustrator export). Package folder contents: net8.0, router (win-x64, win-arm64), icon, manifest.yml.
Question: What else can cause “ID already in use” here, and how can I find what is holding the ID?
