Can anyone shed some light on why these surfaces do not join as expected?
It must have something to do with them having singularities, yet I never ran into this type of problem and although that might be because I never had this situation in a model, yet it feels buggy they are not joining.
Select all and run _Join. It does join but not into a single polysurface.
How were your triangular surfaces created? I did both 3pt and 4pt at your locations and they both joined without issue. I then did a curvature analysis on your original surfaces and they are not planar at the Apex
They are straight lofts between the 2 sides. In theory they are flat, it’s just the mesh that messes up I guess.
I’m planning to use these surfaces for mapping to and from surface pairs in 3D and flat (on a layout)
Think of mapping a logo onto the 3D surfaces and then using a scripted flowalongsurface to map them onto the 2D layouts.
I do wonder now if I will get unwanted distortions at those singularities…l better test that now first.
EDIT: just tested and no noticeable distortions at the singularities.
if you select all the surfaces then _ChangeDegree, they will then join… even if you don’t actually change the degree (keep the U & V at 1… just run the command on the surfaces though)
i don’t have an explanation for this… just adding some clues to the mix
