After pasting a bake into a blank drawing the dimensions come over as Inches-Decimal. When I double click a dimension and go to Length Units it shows as Inches-Fractional and trying to change anything associated with Length Units makes no changes. However, I can go to Arrows in that window and change the end styles/etc just fine.
If I enable Alt Units … Inches-Fractional works fine there … except I now have two numbers on the dimension line … which the decimal number is undesired.
In Rhino 8, when you use the new components for annotations, baking will keep that number as a variable. I see you are using Rhino 7 and I’m not sure if there are Grasshopper plug-ins that will do that.
That’s correct - there is no automatic porting of customizations.
The toolbar system and color set-ups are completely new in Rhino 8 and it’s advisable to do that over again. You can export toolbars from Rhino 7 and import those, but toolbar buttons in Rhino 8 are vector based; in Rhino 7 they were bitmaps.
Annotations are saved in 3dm files and you can reuse your custom templates in Rhino 8. I’m not sure what “layout directory locations” refers to.
I’m up on V8 and working smoothly now. Selecting Edit Linear Dimension and changing the number to a variable with <> makes the baked dimensions pick up the annotation style from the blank base 3dm file template. That helps to know.
QUESTION: Is there a way to setup an Aligned (or other) Dimension object) to make it bake directly as a variable so I don’t have to manually edit every individual dimension in each final target drawing to get the needed annotation style my customer is asking for?
I have 170 shop drawings on my plate for next week and I would be really excited to find a way to avoid manually changing decimal to fractional annotation styles on a couple thousand dimensions. LOL :^)
(A thought: Looking at this from a user perspective, it would be great if Grasshopper dimension objects could pickup the Current Annotation Style of the 3dm that GH is directly working with and bake that in the result. )
