How can I edit an existing Toolbar button? Whenever I attempt to do this the window closes before I can select the button i want to edit.
Is the toolbar docked? I have had that problem and undocking the toolbar seemed to allow the menu to stay visible so I could edit buttons.
Try resizing the toolbar or moving it to a different position before you edit it; that might help keep the window open. If that doesn’t work, consider checking for updates or reloading your workspace.
I unlocked/undocked the toolbar, selected the edit toolbarbutton command. If I moved the mouse at all the button edit window would close. I found that if I hit the downarrow on my keyboard 5 or 6 times, before moving the mouse, the edit window would stay open.
