Unable to edit subd plane using box edit in Rhino 8 after update
Hello guys,
I used to edit the dimensions of objects in Rhino by using the edit box to get the exact measurements. However, after the last update for Rhino 8, I encountered an issue where I couldn’t edit the dimensions of a subd plane. Every time I tried, I received an error message saying “Unable to transform the object”. This functionality used to work well for all objects, but now it’s only an issue with subd planes. Is there a solution to this problem?
Hi @yara.barakat2712 ,
I’m not seeing this issue using the same values you showed with a SubD plane.
Can you post your file please along with the text file saved from the SystemInfo command?
Hi @BrianJ and @yara.barakat2712
I’m seeing the exact same thing - see video.
-Jakob
System Info
Rhino 8 SR8 2024-5-17 (Rhino 8, 8.8.24138.16021, Git hash:master @ 70a9d2157099e610ee64adcb72458b4742ef050f)
License type: Commercial, build 2024-05-17
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 95GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24138.16021
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Thanks @Normand I got it now… it appears that the orientation is a factor.
https://mcneel.myjetbrains.com/youtrack/issue/RH-82084
@yara.barakat2712 ,
Do you recall when this worked as expected? Was it in an earlier Rhino 8 service release or an even earlier version of Rhino like v7? We’re trying to narrow down where the change responsible occurred. Thanks.
@Jakob Normand, thank you, that’s exactly what happened to me.
This occurred shortly after the latest update of Rhino 8 . I am unsure of the exact date, but it was sometime between May 18-21, 2024.
