Unable to control the orientation of the triangle
Hi all,
I made this triangular panel that has an arrowhead (in yellow)
However, due to the order of the points, the triangles are pointing in a certain direction.
Could you give me some advice on how to achieve the following?
Current orientation
Desired control to orient the arrowhead towards centre of a pack of 6 triangles Or even randomise the orientation of the arrowhead.
Grasshopper file attached.
Thank you in advance!
260929_TRIANGLE_PANEL.gh (29.4 KB)
Hi.
First if you are using any plug-ins it’s best to specify it, because not everyone has the same plugin. I had to download it.
Funny thing is I didn’t use it at all.
If you want a relation to the cell centers then you first need to create your grid with that relation embedded into it, that is have all 6 triangles of a hexagon belong to the same list. If not you are never going to achieve it.
Also I think you were overly complicating things to generate your shape with boolean intersections when its just a filleted polyline moved in space.
260929_TRIANGLE_PANEL_RE.gh (26.1 KB)
Thank you, Shynn!
It gives me a new idea of how to achieve it.
I have recreated the grid to maintain the order.
I use the Boolean, as i would like the triangle panel to have a convex quality to it.
Is there a better way to create it otherwise?
Also curious to know if i want the arrowhead to be randomly oriented within the cell. How could that be achieved?
I guess you can randomly rotate the shapes after by increments of 120 degrees.
