I was surprised to discover I was unable to Bake the result of an SDiff involving 2 Closed Breps. I’ve done this a zillion times and never had this happen. I made a simplified GH file that contains only the 2 internalized Breps and the SDiff:
Here are the Inside and Outside Breps:
This is what GH shows as the result of the SDiff:
The problem is the Bake function for the SDiff does nothing - GH & Rhino behave like no command at all was issued.
So what I did was bake each Brep independently, and then use Rhino’s Solid/Difference menu commands to make the subtraction. This worked fine.
I’m clueless about why this should happen or where to even start looking for a solution. Could this be some sort of singularity quirk?
NoBake.gh (12.3 MB)
I think the outside brep has a couple of self intersections. It is fairly obvious on the top surface
It seems there are more self intersections on the jagged part of the object
I subtracted a box from the top of the object so the top edge is flat but the result is still invalid.
So you may want to shrinkwrap the object before subtracting the inside…
The result is a closed mesh
YesBake.gh (13.3 MB)
Thanks Martin - I see your point (pun intended.) I had thought that becuase I had a closed Brep everything would be ok. But the pointy parts sticking up are clearly an issue I hadn’t accounted for.
I tried splitting the Brep below the area of the points, and then Capping and SDiffing that. The Cap worked OK,
but the SDiff resulted in an Invalid Brep that looks OK (just like before) but will not Bake (just like before.) This makes me think that internally Rhino is remembering(?) the pointy parts.
I also tried whacking off the top part completely by SDiffing a solid cylinder, but that produced a very strange result that resulted in an “Empty result parameter” from the final SDiff. So there is clearly something mysterious about the original Brep.
The nice thing about doing this as a hobby means there’s never a problem with having to meet requirements or timeframes. So I just changed the object’s basic shape and the problem disappeared:
And I think this shape is better anyway. My guess is there’s something different between how Rhino treats a circle and a more complex multi-lobed curve like the one used for the above geometry.
The fact that the cap works but solid difference still fails when cutting a bit lower proves that the jagged surface has other self intersections.
