For some reason I am no longer able to adjust the Type Mark parameter through the Element Parameter node for elements existing in a project. I have a bunch of types of casework that I am trying to change to the same Type Mark, but when I try and adjust the parameter, I get a warning that the parameter is not defined. I’m very confused because I did this exact same thing last month and it worked. It does work for other parameters, such as Width, Height, & Mark, but it doesn’t work on Type Mark, URL, or Description.
I have tried to use the inspect element node as well, and it shows nothing. I have tried querying the elements… and same problem.
