UI Text desaturated
recently all text in the UI went very light & washed out. any clues ? thnx!!
plae_text
Hello - was there a Windows update or a Rhino one, or both, that corresponds to this? Or a display change?
I did video driver update (that was it)
Just a hunch, try starting rhino in safemode and see if it looks the same.
how do you do that again ? thnx!
If you look in the start menu, there should be an item for “Rhino in Safe Mode”.
same ! everything’s washed out. such a puzzle!
Ok, well I was just trying to isolate it to plugins, which may make use of this, which I’ve seen in the past to be related to text appearing that way.
I’ll look more into it. thnx for the try !
