There is a lot of wasted space in the dimensions properties panels which means you have to drag them wider before you can use them comfortably, then drag them narrower to get your drawing space back. Here’s an example:
These are wider than in R6 (although not perfect there either).
On a hi-res screen (3000x2000) if that is pertinent. Any way these can be tweaked?
Regards
Jeremy
