UI plus doesnt show the results_display block of text
I just started using the UI + and i see that connecting the inputs such as number slider works fine but i want to sea the numeric results in the same window as well. When i connect the component called display block of text, the preview of the window will be nothing expect the the number. So whenever I add the display text, I loose my number slider inputs.
Is it a bug or it is another way to display the results of a script in UI plus?
