UI issues on GH scripteditor
Few comments to the scripteditor UI:
The red bars of exceptions show to the far right side and i cannot read the text.
And if I click “go to problem” i get this bar, but it’s stuck - i cant remove it again and its on top of my text. Super annoying. Closing the window and opening doesnt fix it.
This is definitely unexpected. How did you get it to show the yellow problem popup? Where is the “Go to problem”?
mouse over on bad code:
Ugh. That should not be there. Okay. I made this YT and will make sure it is removed. There are lots of improvements in Rhino WIP related to errors showing up notably to make it more create that you can click on the red error banner to pop-out the terminal and see the full stack trace.
RH-94610 Monaco squiggle diagnostics show “View Problem” and show uncancellable popup
Errors in Rhino WIP. Clicking on error banner shows stack trace and clicking on (X) clears the error.
RH-94610 is fixed in Rhino 8 Service Release 32
