I’ve noticed a number of annoyances. I posted these under “PaperCuts” because they don’t hamper the modeling functionality, but I think they do need to be addressed.
- When you use the filter, the button on the status bar doesn’t change colour to indicate an “on” condition like the rest of them do.
http://screencast.com/t/KBNkXCeJe
- The OSNAPS and Filter are almost impossible to dock at the ends of the command line.
http://screencast.com/t/otfwEpbU
- The status bar info pane is quirky. I like to only show the minutes since the last save. When I uncheck the others then press enter to save, or just left click to save, the command prompt pane reverts back to the top. I also find that the settings don’t stick. I haven’t figured out yet what makes them go back to a previous setting. I’m not sure if it can be reproduced on demand, or if it’s indiscriminate.
http://screencast.com/t/pwGkynjcEO
Actually, I take that back. I see what makes it lose my settings. Just click on another button (gumball for example).
http://screencast.com/t/ZF20OITTcsI
- When your toolbars are locked, there is an “artifact” in the lower right corner when you open a session:
Thanks,
Dan
