I know there is lots of grumbling about 4K and V5 and I’m not really interested in opening another thread on that.
What I am experiencing is something else. My UI looks satisfactory to me.
When I try and open a file (Via file -> open ) the UI glitches and the rhino window “restores down” to 1/4 size. When I maximize the rhino window the UI is all glitchy and sized wrong, unusable.
I understand. I’ve seen it myself on a high-resolution laptop I have.
The hack is to tell Windows 64-bit V5 is not high DPI aware so it treats it like 32-bit V5.
The way the V5 display was designed, it did not adequately anticipate 4-5k displays.
I see that occasionally on the Intel video chip on this Surface Pro 4.
The only hope is for a video driver update that addresses the problem and I don’t think that’s likely.
The real “fix” will be V6, as it is designed to support these very high resolution displays.
I’d suggest a driver update and make the two recommended changes in the nVidia Control Panel for the Quadros detailed here: http://wiki.mcneel.com/rhino/nvidiainfo
Not the forum for it but in my past experience windows 10 update has overwritten my driver updates with older versions it deemed best for mysterious reasons. I’ll give it a try though.
