HI ,
I am struggling in order to find the way to unitize U and V direction for a list of surfaces.
to start with , i was trying to make a definition to correct the uv according to a set of reference surfaces but then realized that the _Dir command in rhino is working differently ( i guess ) from corresponding native component in GH, let me explain.
if i work in rhino and launch _Dir command on a given surface i get this
if i push on Ureverse i actually reverse the U vector
if i try to do the same using native SrfReverse component i get this
if i set reverse U to true i also V is changed…UV vectors seems to be somewhat swapped and reversed
so my first questions are :
- why is this happening …shouldn’t GH be working as rhino ? GH is very messy compared to rhino
.2) my need would be to compare UV of surface list B with corresponding surfaces from List A but when i compare the UV and act to eventually change only one of the two as a result everything is messed up. can any one tell me if attached definition make any sense ?
thanks in advance.
20260611 UV surfaces.gh (144.8 KB)
