Typos in Rhino6 "New in V6" menu bar
In Rhino 6 beta (6.0.17325.8311, 21/11/2017)
Here are two typos in the “New in V6” menu bar ‘tool tips’ or whatever they are called (when you hover the mouse cursor over the icons in the “New in V6” menu ribbon).
Apologies if these have already been notified.
1). “Dvelopable loft from two curves” (for Command: _DevLoft) - should be Developable
2). “Remove naked mico edges” (for Command: _RemoveAllNakedMicroEdges) - should be micro
Hi Ian - thanks, we’ll fix it… DevLoft looks correct here but I see the mico edges.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43029
Use ToolbarReset to see the latest - as far as I can see the DevLoft tooltip looks right.
thanks,
RH-43029 is fixed in the latest BETA
The following typos are still persisting in the latest V6 beta (6.0.18002.10461, 2/01/2018)
These typos are in the “New in V6” tab menu in the tooltips when you hover over the icons:
“Dvelopable loft from two curves” - (for Command: _DevLoft) - should be Developable
Did you run ToolbarReset like requested?
@Wim - Oh yes you are right. Funny though the new beta doesn’t do this by itself.
One reason for this is that you might have made modifications to the toolbars and we don’t want to automatically overwrite those.
