I’m testing out rhino in revit (RiR) and I’m having the worst time in my life honestly!
I looked up tutorials and documents, it looks like everything is working for everyone except for me for whatever reason.
here is a simple py3 node in grasshopper (rhino 8) ( Rhino in Revit 2022.1 )
point = rs.AddPoint(0,0,0)
a = point
Error : TypeError: Rhino.Geometry.Point3d value cannot be converted to Rhino.Geometry.Point3d in method System.Guid AddPoint(Rhino.Geometry.Point3d) ==> pointing at point = rs.AddPoint(0,0,0)
I have even found a tutorial who were doing the same thing and it worked for him
could someone please help because I don’t have that much time to self-educate myself and I’ve already spent significant amount of time debugging issues that shouldn’t exist in the first place.
This is obviously unexpected and should not happen. Let’s try to figure out what is your Revit+Rhino+Rhino.Inside.Revit set up. Seems like you are running Revit 2022.
Would you mind sharing your Rhino SystemInfo and the version of Rhino.Inside.Revit you are using?
The error in the shared video above, seems to be happening because two different version of Rhino API is somehow loaded in Revit. So it is good to know what other plugins are also installed and loaded in your Revit.
I only have Revit 2025 on my machine and a simple python script like this Grasshopper 1 is working just fine. @Japhy my coworker tested Revit 2022 and it is working on his machine as well.
